Re: 81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
Jay, put your gimbal housing on the boat before you install the bellows...
I repeat, Put your gimbal housing on the boat before you install the bellows...
I just got done with my bellows/shift cable/ and gimbal bearing.
1. The gimbal bearing went very smoothly, in and out, snap ring went in without TOO much trouble.
2. Tapping the hole for the shift cable was a cinch...since it was already tapped all the way through BUT even the special socket from mercruiser would not fit. I had to grind the inside of the bellhousing just a little bit and it fit.
3. Bellows suck, especially when you have nothing to push against. You need to be able to push against the gimbal housing so the bellows will fit.
I followed the manual and its instructions seemed to work without too much trouble except the u-joint clamp on the bellhousing side which I used an extension with a swivel for. I also had a special swivel screw driver for the other hose clamps.
The exhaust tool works and I don't see doing the job without it, but it could be improved upon.
