buxmj
- Jun 9, 2018
- 294
Hey Sam, as always thanks for the insight, that does make sense. Yes, there was no foam and no fore to aft stringers, just lateral bulkheads, I will post a deconstruction pic later but what is even more scary is that the bulkheads were dimensional lumber so they didn't contact the hull once the spacing was taller than the stringer so really there wasn't much if any support along the keel. I have already cut one more stringer than was there before and they all will contact the hull all the way across. I also am planning on pouring 2 lb foam, let me know if I should use 6 lb. I have the 1/4" ext ply cut and can go that route. I will lay them in there tomorrow and take pics and see what you all think. I definitely want to make it better and stronger, the original transom was only an inch thick and the outer transom skin is PAPER thin, the new transom is inch and a half and I will add to the outer skin before I put the new transom in.
