Re: '1990 Bayliner Capri 2050 BR - Deck, stringers, transom, custom interior'
lowkee
Just blasted thru the whole thread and suscribed to it...15,000 looks NICE (took quite a while!) and watched a few vids. Nice Job! looking good! I feel your pain! we have a project going too, similar amount of work and same troubles (better hull than yours though), not as hacked up...
jeez bunch of fools owned your boat previously .....really took care of her LOL.
Super sleek hull design, very sweeeeeet!
You went nuts with the flooring, should be bullet proof... bet those ply panels were heavy when you were done!
What a pain yanking the top half and such,
are you able to re-use the rub rail aluminum and rubber? that stuff is PRICEY!
I havent had much work for around 5 months, so I decided to "flip" boats HA HA HA dummy me! picked a full on resto for first job. Shoulda got a bettter boat for a few more bux! we are 2 weeks (actual work days) and are almost ready to install decking, we kinda FAST TRACKED... didnt cut too many corners...doing a good job etc.Did the stringers and such..
..It's LOTS of work Im finding. Looks easy in pics lol
Sorry you had such a bad time with the HF spray gun, I had the $10 version (not the hvlp) the normal sprayer type. It worked excellent. Then bought a $350 HVLP gun, it used less paint and adjusts ALOT so can airbrush or slop on paint.
I'm going to attempt GEL COATING with it using a big tip for the gun.2.2mm I Hope it works out! $47 per gallon --- worst case we'll roll it on and wet sand / polish it out. Ill let you know if it works out either way for your future projects...
we will be using House of Kolors automotive sunrise orange pearl on top half with clear coat, gel coat on bottom half. looking fwd to seeing your pearl job.
Too bad summer is about over, maybye she will be done for some fall fishing? Keep up the great work!!!!!!!!!! We will be watching.....muu haaaaaaa haaaaa haaa!
