I started the day by trimming and sanding smooth the overhanging glass at the top edge of the stringers. Next, I made templates for the rear bulkhead and the ski locker floor. I still had the old ski locker floor and did some test fitting with it before switching to foam board.
Foam templates for the rear bulkhead.
Rear bulkhead pieces cut out of 3/4" plywood and foam board template of the ski locker floor.
Ski locker floor cut out of 1/2" plywood.
I went ahead and laid glass over the top edge of the center stringer, which will be under the ski locker floor. I want to make sure I know the exact height of the ski locker floor where it hits the rear bulkhead so I can put my drain in the proper location. My plan is to go ahead and glass the back of the ski locker floor and then that should give me a better idea about where to put the drain from the ski locker into the bilge.
