JDA1975
- Aug 27, 2011
- 1,385
Re: 1982 Skeeter SS-1 Sport Fisherman Restoration....Need some advice
OK, so after hours of futile sanding on the one side...I started the other side, and learned something, the area I am having so much trouble with is the very first section i filled, it is still a little tacky, yet the rest of the boat sanded down great. I believe I did not mix in enough hardener with my first batch and it still has not fully cured. I still have that area to do , so not sure if I am going let it sit a while to cure or just use a lot of sandpaper! anyhow, here are some update pics. all the scratches you see are really filled, and smooth so when i prime it should look smooth!
keel shaping done
keel shaping done
