jigngrub
- Mar 19, 2011
- 8,155
Re: 1982 Glastron Hpv165 bass boat restoration.
I'm of a mind that if I'm going to go through all of the time and trouble to take a boat apart, everything is going back in new... especially in a 30+ yr. old boat. There may be concealed rot in other areas you haven't touched on yet, you just never know about these old boats and the way they're quickly slapped together on the assembly line. I believe you stated earlier that the glass work below deck was sub-par anyway... and this is pretty typical in just about all the resto's we see on this forum. If your stringer only has rot on one end, it has still sucked up water into the other parts that seem solid and raised the moisture content which will lead to further rotting later... especially when it's covered over in new glass and that moisture is trapped inside.
To me, a halfway solid stringer means I get a nice solid template for the new one and this save time instead of having to scribe a new one in from scratch.
About your hull cuts and working conditions:
For me, heavy cutting and grinding/sanding is an outdoor activity during daylight hours. The quality of your work will be much better than trying to work in a fog of dust.
I know it's cold where you live, but with the proper outter wear it's not that much of a problem, and the quality of your work and the speed at which you can do it will be worth it... and you won't have a huge mess to clean up inside.
The plastic tent you're woking in now will be a dandy fine place to put the boat back together in, but for taking it apart you should really consider being outside.
These are just my thoughts and other may have a differing opinion.
Should I keep gutting out all of the old structure and start over new?
Is there a good, solid and safe repair that can be done on the existing well preserved structure to save time and money?
