Luposian
Thread starter- Joined
- Aug 15, 2015
- 119
Thank you for your detailed response. Now, I'll reply:I just read through your project. I've been repairing boats for a bit over 11 years now. Here are my thoughts.
Bracing: What you did should be fine. If it was me though, I would bolt some blocks to the outside, through the rivet holes, amd use ratchet straps. You can adjust them easier if needed, I think it would be more secure.
Floor and Stringers: Hopefully you can still see the old floor line on the hull. Make your stringers a bit taller than that, set them in the same places, and trim them down later. It's so much easier than cutting too short and having to work around that. You'll need some boards screwed across the tops to keep them in place, set them in with thickened resin, and will be glassing along the sides to attach them to the hull. Do the entire stringers, floor, and might as well do the transome too.
Foam: Take it all out, it will at best be in the way. Use a reciprocating saw to cut into squares, then a flat bar to pry it up in big chuncks. Quick, easy, and clean. New foam should be poured in after the floor is done.
The Cap: Don't do all of that mixing and matching with bottles and extruded poly foam. Some two part or spray cans when everything else is done will be fine. In this case, maybe spray cans. The two part might be a bit messy for that job. If the wood on the rear needs replaced, don't go side to side. You need those open areas to glass to. You can add small plywood blocks to support deck hardware now too.
At the beginning of this, you said you didn't care about time or money, you wanted it right. It's definitely going to be a lot of time and money to get it there, but don't skimp out.
I'll add more detailed responses as the project goes.
- The internal bracing I did (trying to hold the hull in it's "capped" shape) failed. I tried keeping the hull from popping out (along the sides), after removing the cap. Didn't hold. So, the hull "foompt!" out. Oh, well.... 'tis what it 'tis. Crying over spilt milk solves nothing. Deal with the bridges as you come to them. :-D
- I haven't touched the stringers/bulkheads yet. There is only a little section of the floor left in the bow (about 2') I need to cut out, to clean out the last of the rotted (it's super crunchy and it's as brown as pumpernickel bread!) foam in there. I haven't cut out or ground away any of the remaining fiberglass "lip" along the edges. I was originally planning on using it as guideline, so I know how thick my plywood pieces need to be, to just fit under it, snugly. A note on my iPhone states the flooring plywood is 1/2". If the resined fiberglass is what truly becomes the stringers, even if the core wood rots, which it has), then they still seem quite solid. They look sloppy as heck, but they're rock hard. I cut out and removed the transom as well. That wood was rotted, too. Not quite the "mulch" the floor was, but not far from it, either.
Everyone says grind everything out and down to the bare hull, but that's beyond my pay grade. While I could probably successfully do it, I'd have no clue how to get back from it. I've done what I feel "safe" doing. At worst, I'll have a professional grind the rest out and build it back up. At least I've given them less work to have to do.
- As my last photo shows, I've removed all the foam. It was under the bow section of the cap The dry, brown crunchy stuff was just thin strips along the outside stringers. I'm assuming the stuff under the cap was from the factory, but the stuff under the floor was 3rd party mod (including the pink house insulation foam sheets where (I assume) the ski locker used to be)
