1976 22' Starcraft Islander Rebuild
jasoutside
Re: 1976 22' Starcraft Islander Rebuild
Ah sheesh Grandad! Yah man, I NEED MORE COFFEE!!!!:twitch:
ShowMeGuy
:topsy_turvy:
Hey Jas,
I think you better take the bigger boat and especially the new GPS. You're likely to need it, or more coffee, since on my maps the ocean is on the east side and the flats on the west. - Grandad :D
HA! I was about to say the same thing.... JAB JAB!!! Good thing you got that new GPS!!!! :) hehe
ShowMeGuy
On the boat options for our HHI trip:
I do believe if I had my way, I now think I'd rather take this Islander. You fellas make some good points for sure. I do see the disadvantage in fuel burn on the way down, but that shouldn't be too bad. There's also the disadvantage of not being able to get into the skinny water. But, I do think the advantages of "family style fishing", safety margin with the bigger rig, and having the cabin to get out of the weather sort of stuff may outweigh.
So, here's the deal...
I was thinking that the finish line would be sometime during the summer of 13. Well, that's bumped up big time now!
The GOAL for the Islander is now 3/28/2013
I say goal because I have no interest in rushing, cutting corners or killing myself on this project. I'll need to "just keep the blades turning" and work efficiently. If I can pull it off, sweet. If not, hauling the SN down instead is certainly cool too.
So, game on:peace:
I would be thinking on the same line... Safetly is always higher than fun on my boat..... I hope you get to take the big boat down. The extra fuel? I mean.. big dealio.. how many times you planning on making a trip to HHI? I mean, just saying...
64osby
#2 So this morning I was sitting on the newly installed starboard side seat box. Thinking. Thinking, thinking, thinking.... Coffee. What was I thinking? Well, I was kinda thinking what it might be like to haul this Islander down on our Easter Break Trip to Hilton Head Island rather than the Sea Nymph. Hmmmmmmmmmm........
More coffee less thinking
I think the Islander would be a much better choice to bring along....................
You better get busy.
Posted Nov 29th on the SN thread. :boink:
East - West Just turn the map upside down, you'll be fine. :der:
jasoutside
HA! I can always count on my iboats bros for a quick kick in the junk to keep me on my toes!
:boom::flame::boink::whip:
64, you did call it man, credit your way my friend!
64osby
No credit due, but cash is always good.
Good thing you'll have a couple weeks off at the Holidays. Game On. You're the one doin all the work.:juggle:
dmoriarty51
will you be able to find open water at home to do a sea trial before you drag her across the country?
bear_69cuda
_____________________________________________________
Complete and total change in direction real quick. I was yacking it up with an iboat buddy off the forum regarding electrical stuff. So....
On my rigs there was a certain point where I was sold on the ACR. Well, until I found a few posts like this by silvertip (I wanted to be sure to give him credit):
So yah, I'm buying what he's selling. I just wanted to drop that in here so you guys know why I didn't go with the ACR anyway. That's just me though eh:joyous:
I know Silvertip is a very wise and all knowing guru, and his 1/2 both switch is very simple, and does exactly what he says, but he misses some important pro's for running ACR or VSR. On my boats, I want a starting battery only to do just that, start the boat, and not have other electronics sucking power from it... I want everything (all electrical) on a deep cycle house bank... And I don't want to worry or remember when to switch one or two, or both.... I prefer dedicated battery systems, and use a VSR/ACR to isolate and charge them. If my dedicated start battery died, I can still use my house bank to start my boat... The ACR also can help protect/isolate circuits from transient voltage caused when cranking your engine occurs. The fuses that protect the GPS, and other expensive goodies can possibly fry... But then you need to deal with that... Below is a good read on why ACR's have some advantage over simple switch only systems. If you still decide not to use a VSR I totally understand, but at least get dual-purpose group 31 batteries so as not to use a cranking battery for house electronics, especially a trolling motor.
Love Bear
The ACR is typically wired so that an auxiliary battery is placed in parallel with the main battery (by the switch closure) when the sense voltage is above threshold, that is, whenever there is charging current available and the main battery voltage has reached full charge.
This simple circuit has been enhanced in several ways. The most common is to include a hysteresis in the sensing circuit so that the ON voltage threshold is higher than the OFF voltage threshold. This helps to prevent the circuit from chattering on and off. Without a separate threshold, there could be situations where the addition of the second battery to the charging circuit would immediately drop the voltage below threshold. This would, in turn, immediately cause the relay to drop out. And this would then raise the voltage. The cycle would repeat. Having some hysteresis in the control loop helps to reduce this tendency.
One of the principal advantages of using an ACR or VSR is to help isolate the electrical circuits in the boat into two distinct groups:
--battery and loads associated with engine starting
--battery for all other loads
The engine starting loads are typically just the engine, its solenoid, and its starting motor. The other loads are vessel lighting and electronics.
The reason for maintaining isolation is twofold. On engine start there are often voltage transients produced. These voltage transients can cause interference with or damage to electronic devices. Isolating the starting loads from the electronic loads will prevent starting transients from reaching the electronics. The other advantage is isolation of the starting battery from discharge by any load except the engine. This will prevent the starting battery from being drained by non-starting loads (such as lights, pumps, or electronics) when the engine is not running. Larger horsepower engines are very difficult to pull start, so it is paramount that the engine starting battery be kept fully charged and able to crank over the engine for starting.
The general design of an ACR or VSR has been intended to only connect the two battery systems when the engine is running, that is, when the engine is putting out charging current and the engine starting battery has reached a full-charge terminal voltage. In most cases this will occur only when the engine is running. However, it is possible that if both batteries are near full-charge, an ACR or VSR could be fooled by the high resting voltage of the two batteries, and the voltage on the sense line may be high enough to trigger the switch to the ON condition. This will parallel the two batteries, even though the engine is not running.
The harm in this comes when the engine is cranked over for starting. If the ACR or VSR has paralleled the two batteries, voltage transients from starting may reach the electronic loads. If this occurs, one of the main reasons for using an ACR or VST is lost: the electronic loads will not be isolated from starting transients.
To overcome this situation, Blue Sea Electronics have developed a more sophisticated version of the ACR. They call their device a starting-isolated ACR. The ACR switch is always opened during starting. This is implemented with a simple circuit which monitors the engine starter solenoid line. When the engine is cranked, voltage on the engine solenoid line is sensed and the ACR switch is immediately opened (if closed). Blue Sea says that the switch operates fast enough that it is open before any transient voltages develop during cranking.
jasoutside
64 - Yah buddy, I still have a long road on this Islander. One bite at a time broham:joyous:
moriarty - The Bay should be open at that time (Lake Huron) though it'll be a cold run for sure. Certain of one thing, this boat will need a few solid runs before I haul her all that way!
bear - Here's a little something that PMC sent me. He called me an "old fart" and said "get with the times loser."
Pmccraney
Hi Jas,
This is my first post on iboats. I discovered this site a few weeks ago and I have dissapeared from all other interactions with the outside world... .
Yeah, this place is like HOtel California... No turning back... You are one of us now- talking about boats constantly to bide our time as we wait for the special comet to arrive...
(but the marsh is very shallow and swings with the tides, so you would be somewhat limited on the west side..)..
Guilty as charged but, in all fairness, I did try to drop you a subtle hint that the Atlantic Ocean is, in fact, located on the Eastern side of the continental United States... Be careful out there, Magellan.... :watermelon:
c.peet
I was going to mention Jas' sense of direction is as clear as my sister's... when she's drunk... but I thought it might not be appropriate for a first post, so I saved it for my second :D
With the choice of boats, they seem to speak for themselves. First you have a Nymph; a mystical maiden or goddess of the sea. Alternatively you have an Islander; an inhabitant of an island. Dood YOU'RE GOING TO AN ISLAND!! For name's sake take the Islander!
Unless of course you hold some fantasy about getting a nymph wet :D
GA_Boater
Well OF, did you learn anything from the vid? Get with the times and look at how that guy mounted his batteries - on the bulkhead and sideways. I duck now. :behindsofa:
I asked last week of you were moving the SN to the back burner and fixing the Islander for the HH trip. Now it's confirmed. A good choice I think. She can handle bigger water to the East and even some of the skinnier water to the West. The big gal is a far better option. The tidal flow is a lot more than the Great Lakes, up and down about eight feet between high and low tide I think. Think about a VHF radio if you haven't already.
And oh yeah, get to work. tick, tock,
jasoutside
So yah, this new guy. c.peet is his handle. Yah, he's an Aussie you know. Apparently he can dish it out...
Bah, those stinkin aussies:doh:
Only thing worse are those darn kanucks, eh!:canada:
Yah man, tide isn't even a topic up this way. I'll need to get learned up a little for our trip.
Yah, VHF is on the short list. I need to do some hunting there but that will be far less painful on the budget than the FF/GPS.
Now where is my shot of PMC wearing his wife's slippers when I need it!:cupcake:
GA_Boater
Jas - what FF did you get? D we have ro wait until UPS leaves a box at the front door. I don't recall any details except Down Image (DI), the Humminbird word for Lowrance Structure Scan.
Pmccraney
Look...very carefully.... at the last video I posted in my SN thread... You might see them making a brief cameo.... :watermelon: (p.s. I got dibs on the watermelon icon; its my own personal AYUH).
jasoutside
+1 about those darn kanucks and their canadian back bacon! :violin:
AH! Forgot about kanuck bacon! I love my neighbors to the north!:kiss:
(What, smooching not allowed on iboats?)
Hang tight GA, it's on the way. I'm darn excited I was able to score one, uber important piece of equipment!:thumb:
So what's mine gonna be then? This guy?:hat: Maybe this dumb llama?:llama:
jasoutside
OK, progress, port side seat box getting glued up. Nothing fancy here, just a plywood box getting glued...
I had a few minutes after that got done so I jumped over to the SN...:joyous:
