Re: 1975 Starcraft Mariner 18'
I liked the part where you applied 5200 all over the bottom edge of the transom board.
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Not sure what exactly you're waterproofing there and someone someday will be cursing you when they try to get that board out again
I thought about that for awhile and figured it couldn't hurt to have a little extra protection on the bottom edge of the transom I figure if water ever gets in to the wood it will be from there or the bolt holes somehow. So bottom edge has probably 6 coats of epoxy, some primer and some 5200 to keep the water out of the wood should be ok
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I don't know if it will stick really well to the shelf or not it was cleaned but still had an oxide layer on it I figure if it does stick it shouldn't take toooo much to pull the primer off hopefully I never have to find out
It looks like yous should have enough room to just hang in on the transom next to the big motor
,... Teamster I see some of the holidays and SS's that have a kicker right on the transom but I think they are a bit wider on the rearend. I'm also not sure at this point what I'll be using for a kicker (shaft length) so we'll see. I sort of remember checking it out while I had the motor on and thinking I couldn't fit one on the transom but if I can I might. I guess maybe it seems like the way the splashwell is set up with those flat places and angles inward toward the back that there is a lot more transom outside than inside if that makes sense?
Starcrazy post those pics before the angry mob catches You.
Thanks for the replies everyone all I managed to get done yesterday was some rearranging in the garage and hauled in the plywood and stuff out of the trailer, the 5200 is setting up nicely I plan to let it go the full 7 days before I try priming or anything. I'm cooking dinner now and then hoping to get the rest of My garage cleaning done and cut the last 2 floor panels and start epoxy. More later I hope.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
