Re: 1974 Starcraft Chieftain 18' OB refit
This is the first time I've heard anything negative about Easypoxy but I will follow the directions and hope for the best. The hard part is the 4700 epoxy primer must be top coated in 3-8 hours and I'm conventional spraying 2 colors. I will shoot the white on the bottom first then I have to tape it off and shoot the black on the sides within 8 hours
I can go back later and fix the white under the tape if need be after both are cured. From what I read here the Majic hardner is what to use on this stuff...No?
I needed to use a good epoxy fill primer because I need to fill a bunch of small pitting and I liked what I read about the 4700. At that point I wanted to stay with the same product line. I could top coat with rusto but the pro stuff is supposed to have better gloss retention and last longer. Besides, after spending good money on the base coats it makes sence to go all the way with the same line. Hope this proves out over time.
