Re: 1973 SRV 220 OV Resto
well, all the hardware i could get off the cap has been removed. also removed all the the snap fittings for the canaopy/enlosure it had at one time...ground down all the spider cracks in the cap and filled them back in...mostly along the outer edges where you can walk. i found out that most of the cracks were from underneath the edge of the cap where the plywood backing is (or was)..it looks as if there was originally 1/2" ply on the bottom side of the cap, but most of this play had broken off in pieces, so only a thin layer is left where it is affixed to the fiberglass..i'm going to cut strips and epoxy/glass new ply underneath these walkways and reinforce the cap. I'll do this when i begin to make the structures for the rear seating..
I have also filled in all the holes that were left from removing all the snaps and other hardware that i'm not putting back on, or just relocating to new spots.
The entire cap is now sanded down, finished up with some 120grit...had to call it a night after getting stung by a wasp while trying to disassemble the dash..I have discovered several wasp nests in her so far...not good to have, esp. when your allergic to them...
tonights plan, go all rambo like on the remaining wasps nest, and then begin to mask off all the edges so i can get ready to paint the cap...fun fun fun..
I'll post some pics tonight of the work so far
