- Jul 23, 2011
- 52,813
True thatok, then its the design engineers fault
what was the failure mode.Replaced my 3 bank again (2nd time) few weeks ago
Thanks. since fuel and water are on the starboard side, I made the assumption that the shore power should go there. however thought I would ask.Original was pro mariner and would only charge flooded
2 was charles model and middle bank just stopped charging
3 new is pro mariner
Shore power connection starboard side above swim platform on stern
The leak is the back to back seals for the forward prop shaftI think VP does some great design better then Merc, but the DP Nut is off base IMO
At least Merc uses full threads
Best reason. Ever.... and it takes up less room assembled than it does in pieces scattered thru the garage shelves.
