1963 Boston wailer 13 footer
When I called Raptor about building up thicker layers in the cockpit sole, they stated that it was not a good product to build more than 20-40 mils. I was trying to get to about 1/8" thick to withstand the dogs. so I ended up with the EVA. at 5mm
mickyryan
yeah i found on previous project same thing, its not good for that but for bottom where it is uv protected it seems to hold up well , i will use it on the top but not where i walk , i even coated over what i had done on monishka with 2k urathane because it would hold up , that said , im going with eva as well because that stuff feels so good on bare feet :)
mickyryan
i think you will be happy with the eva its easy to clean , does attract dirt but heck i used a el cheapo electric pressure washer on it and never hurt it , this time around i will go with brown the light grey was just too much of a headache to keep clean
zool
Im sure glad there was "NO WAY" we could talk you into another resto Mick!
I had the best times on my whaler way back....mine was waterlogged but i used it anyway :D
mickyryan
picked up a trailer tonite, it was a ezloader, i will be cutting it down and modifying it for the boston whaler! , wierd thing its wide and the axle is like 96 inches lol someone stuffed a different axle under it and rode out i guess lol sadly axle is good but i have no use for it as its too wide for that i am doing.
archbuilder
Lol, I have a boat trailer axle collection......now that I think about it I have a fender collection also. I think after Fugglys and Miss Morgan's trailer modifications, next time I will just sell the trailer, hit the steel supply and fire up the welder to build a new one! hope yours works out well, and of course we need pics!
mickyryan
Fabrication is on my bucket list of things to get better skilled at , i almost pulled trigger on a new welder months back but i havent decided , i know i want to be able to weld ss and aluminum.
i might invest in a new welder, this one is a bolt together for the most part but eventually i will need 2 new trailers, and making them myself would be more fun in the long run, buddy just got a new trailer , welds were horrible and 2 broke , i think i can do better even with my lack of experience lol
G
Guest
Guest
If you redo the transom, make sure you make it a 20", Those short shaft 15" transoms put the rear of the powerhead in the stern wake with anything over 25 hp. (when the hull squats just before getting on plane) I'm sure that 40 Yammer touched the white wash.
You'll like the additional free-board aft too.
kcassells
Ive just been trapped near the inner circle of thought :rolleyes:
Just cant deal with this stuff right now.
OIP.uM9AzJQ6BjU3hJhm0y_EDQHaHa
mickyryan
yep i leveled it out , the yammy is a short shaft so not sure how i will tackle that i can drop it back in same holes as before but then , like you say its in the wash .... i might need to find another engine for it .
mickyryan
well i was forced to weld , lol missus was like hey ill rent one for ya , so i got my feet wet with wire feed welding , once i got it dialed in , it seemed to go well , however i am def not pro status yet , but they shouldnt break :) ill have more pics tomorrow it got dark on me:)
New axle, springs , hardware and hubs,hand greased the bearings, i kinda went crazy withy welder and welded everything i could lol just to get practice and get better at it.
archbuilder
I find that my welds look better in the dark lol! One note, when you weld galvanized material wear a respirator ( charcoal cartridge type). I am not the safety Nazi (I am the guy on the do not do this label), but it does put off some not so great gasses when you weld it. Its not as bad outside of course, but just wanted to point that out. Also, the zinc (galvanizing) contaminates the weld, so make sure you grind it back before you weld. Looks like you are moving along nicely!
sphelps
I have a hard time seeing what I'm welding ... Its hard to stay in the joint if you cant see it ...
Put you a fan and point it at where your welding on the galv . Those fumes will mess up your day for sure ... :painkiller:
