- Jul 23, 2011
- 53,174
is your ignition system points or electronic ignition. 87 may still have points.
that is a GM automotive based HEI ignition cap and coil ..... only legal if it is truely a DUI marine unit (Davis Unified Ignition).
if so, the top coil cover and the marine compliance decal is missing. you may want to investigate that
http://performancedistributors.com/product/marine-dui-distributors/
that is a magnetic reluctor ring triggered electronic distributor.
so, next question, is the distributor installed correctly? or 180 degrees out?
Is it odd that there's a GM unit on a Ford? I'm just curious. I haven't upgraded mine to the HEI, but I intend to do so from the link above. Hopefully, this winter.
I would recommend figuring out what system is on it then find the wiring diagram for the system you have. Also try posting in engine repair and maintenance forums. Lots of smart guys over there.
