kcassells
- Oct 16, 2012
- 8,739
ok separate post for further questions:
- when tabbing the stringer do you cut the glass from the roll width (approx 1,25m / 50 inches ) and do some overlaps or do you use a single piece of the entire stringer length?
- we plan on tabbing the stringer before installing the bulkheads with 2 objectives, make the job more easy and create a water barrier between parts if water ever gets in. odes it make sense?
- 2 tabs of 1708 on each side is it enough ?
- what technique do you use for caping them? I saw some guys using clothes pins to maintain the CSM on the stringer while curing but hen how do you prevent it from sticking to the poly once cured?
- do you put the cleats after full encapsulation to the stringer or do you install before caping and glass them in?
well that's all for this time![]()
Tried to reply but keeps not alowwing me to answer some of your questions.
--You can go full height of the stringer 1st coat glass w/3" lap onto deck and then follow with the next glass 3: wider. This becomes the tabbing.
--Do as much flat work as you can prior to setting stringer.If the wood does ever get wet in any application decribed above then the water will always find a path of least resistant.
--Yup
--cut and prep for any glass to top the stringers etc. wet out and simply trim off the excess.
-- Good question! Yes they go in after. Kinda like they are sacriced for screws. You can always top off the cleats with csm or a poly mix with chopped glass strands.
Like Chevy said.
