- Mar 8, 2009
- 44,664
FYI - from the us composites site
2# density foam has a compressive strength of 40psi, a tensile strength of 30, and a shear strength of 30
3# density foam has a compressive strength of 60psi, a tensile strength of 70, and a shear strength of 50
4# density foam has a compressive strength of 90psi, a tensile strength of 110, and a shear strength of 70
Assuming you still have a 2' x 2' area of 2# density foam, it has a holding force of 17280#
just brain-storming. if you put about 2psi pressure in the tank, it should bulge the sides enough for you to wedge something between the hull and welded corners. then you could put a vacuum on the tank and try to suck the bottom up a bit. maybe you can slowly tear the foam in this manor.
That's an idea, thanks
I can only get to two of the corners easy enough, one not so easy on two of them. The two which is not so easy is on the side which is still holding
