Re: Wow!!! My next restore....1968 or 1967 Starcraft Chieftan aluminum boat
Now, look what I found, I found some rib end cracking, this rib is on the port side only on the one rib. The hull is not cracked at all. You can see the crack where the arrows are marked on the hull. I can see the rib under the floor right next to the cabin wall, it looks cracked too, I do not see any yet on the starboard side. I did some thread searching and saw how someone repaired this with an aluminum plate. Basically, drilling the top 4-5 inches of rivets on all main ribs centre of the boat, making steel bars up and prying the ribs up in order to rivet in a aluminum plate. Under the plate is tons of 5200.
Question: If it is only the rib end that is cracked, could I not just get someone to weld only the rib itself, as in weld up the crack and that is it OR since it is all apart with the floor out go with the plate and really reinforce this thing to prevent any further flexing.
Another picture trying to get closer up....
The Starcraft dealer is telling me I would have to totally remove each affected rib in the whole area, put the plate in and re rivet in the ribs. My biggest worry is messing with the original factory rivets, How would I ever rivet new rivets into the hull and ribs, do I need a special air rivet gun for this adventure??? It is a little depressing here.....I sure do not want to scrap this whole project because of these rib end cracks. I am desperate for any ideas to help me fix this,,,,,PLEASE!!!
