Re: Transom replacement-Turned Complete Boat Rebuild
Hey Vegas-Z bar, thats a good idea, I have some 18 ga 316 SS in the shop, I could bend it up and weld the corners
my wife insisted I set the deck up the exact same way it was originally, I know the hatches are huge, the fuel hatch is 4' x 3'. I am going to make that hatch cover with a small trap door on a piano hinge about 10" square for the 2 stroke tank access & weather strip the main one. I was thinking of locking the big hatch down with duz fastners or just screw it down.
Its hard to see from the photo, the deck crowns slightly in the middle up front, so water runs to the outer edges, pitches back slightly there are 2 channels 1 1/2" wide 1/2" deep that run under the splash well into the bilge, there is also a slight pitch inward towards the bilge hatch. It kinda runs the water away from your feet then into the bilge.
The original bilge hatch was open slat 6" wide planking so it would act like a storm drain.
Gel coat it is in the long run it will probably save me some work down the line
tallcanadian- Thanks for the complement, I should have her finished in a couple of weeks
