HVAC Cruiser
- Sep 12, 2009
- 1,254
Re: Transom replacement
I was looking at a ton of posts myself and saw the same thing, Drewpster
is in the middle of a transom/deck replacement and said something in his post that made alot of sense. It went to the effect of "the boat manufacturer didn't use marine grade and look how long that lasted" .
My boat is 36 years old and its held up fairly well. I believe most of the damage below deck stemmed from a combination of cracked and leaking bait wells and bad deck hatches which allowed the water to soak the foam and just kept below deck constantly wet.
I am going to do it using ACX, and just make sure my glassing is good. I really need to get this project completed, I need my shop back. I even pulled 2 of my guys out of the feild to help get it done faster
I've read plenty of post were people have used A grade exterior plywood. I don't think you need to thin the epoxy when you coat the plywood. I believe a slow cure will be sufficient. Then again I'm not 100% sure, since I'm using poly. I'm sure someone with epoxy experience will help answer that part of your question. Keep up the good work.
