markedenfield
- Oct 20, 2005
- 18
When replacing wooden stringers in a fiberglass boat (19') is it recommended to keep the stringers from touching the hull using spacers? I have read that if you laminate the stringer directly to the hull it will crack the hull when in rough water. However, when you use PB to secure the stringer and then laminate it to the hull, aren't you doing the same thing? The stringer is going to ride with the hull in both scenarios, especially if you laminate the stringer to the transom. As you can see I am new at this and need some help.
I will go ahead and ask a few more questions to get them out of the way before total frustration sets in.
Don't have Douglass Fir for the stringers. I have Southern Pine. Is that ok?
I am using 2X8 for stringers. Is that ok?
What thickness of plywood should I use for the decking?
The boat is a 1996 Moomba Wake Boarding, Ski boat that I am trying to rebuild as a father/son project. Can include pics if I can figure out how. Any help will be great as I am about to cut it up and send it to the scrap yard. LOL
I have not enclosed any pics of before as everything was rotten and imagination will serve well. I don't even have enough stringer left for templates and am having to figure out the angles which has frustrated me quite a bit. Also, is there any need for ribs or lateral support. I know this is like a essay but I don't know how to do this and want to work with my son through completion. Thanks.
Mark
Mark
