Stringers
Re: Stringers
Did you Precoat the wood with resin first? Did you fill all the voids, if any, on the edges first? If not on the first question, the wood will soak up all the resin and the glass will not adhere.
That's the answer. The edges of the plywood were soaking up the resin and it dried out the cloth. I do have another question though. After you apply the resin and glass, is it a done deal or should I periodically make adjustments (add resin) throughout its curing period? And one more, when I lay up the stringers (since they will be vertical) should I thicken the mixture of the resin so it won't sag or run down to the hull? Thanks for taking the time to help me. Mark
rickryder
Re: Stringers
Nice project Mark. You really dont need to thicken the resin. Just work the resin into the glass from the bottom to the top of the stringer with a mini paint roller. If you get some runs you can smooth them out when the resin starts to gel up a bit.....
oops!
Re: Stringers
hi mark.....
sorry i have not check in for a while......
hows it going?
