Re: Still wont start - what's next?
Ok - I'll try the seafoam. I was getting spark on tester though. Starting to get a little stumped now.
Weird part is that I got it running at one point (after about 50 pulls) and then could not get it to fire up again. I did not check compression prior to getting it to start. That is why I changed all electrics - thought may be spark was weak and it was intermittent. The one time I did get it running. It was getting hot though - no water thru pee hole. I shut if down when I noticed i - probably let it run a little longer than I should have though. Maybe I f'd something up then.
thanks for the help. I'd be completely lost on my own at this point.
Before pulling head, I'd try soaking the cylinders in Seafoam. Place motor with spark plug holes pointing up and pour a little Seafoam in each. Let soak a day or two and re-check compression. 55-60psi and even really isn't that bad, and should come up with the Seafoam soak. Even so, you should have gotten some fire by pouring gas directly into the cylinders if you had good spark.
