Re: PROJECT ~ JEZABEL 23' Sleekcraft Executive ~ Turbo Restore ~ Tons of pics
ok im must be in a blabbery mood (or I'm too tired!) because this addition to the post is running on and on! plus theres
some people want LOTS of info so here ya go!
Well....she's getting closer to water! I will install the engine box, add a switchable dome light in there in tomorrow (no sense in workin on an engine in the dark!) and also the jump seats are going in (since were done with the engine compartment now)...., and.........
the wife sprung for a better captains chair ...early birthday present! turning 42! time flies!!!!!! found a nice one that is COMFY for $120 looks better than the Office space chair I was going to use....I really liked that chair too! see pics when posted
got 6 new WHITE cup holders... should match the interior ....those are for all the beer cans!....got those at a local marine supply
Replaced all of the heater hosing to the water headers tonight....replaced the bilge hose, replaced the bilge blower, replaced the bilge exit fitting for the bilge water pump too....that was jerry rigged by PO they had 1/2' bilge exit with 3/4" hose crumpled on there! lets pump water only to have it come back in the boat! PEOPLE....leave the repairs to someone who does it right! or atleast tries to do it right!
what I did the Day before = repairs.Hole patches and big chips in gel coat repairs.....removed the PO drain dohickey they rigged, grindered with a new 80 grit flap disc on my trusty
ANGLE GRINDER! so the repair areas were 1 to 12 dished out on the exterior of the hull.also sanded with 100 grit hull area where gel coat is going...and sanded fairing down....
then I .took a small piece of construction plastic, added 3 layers of circular random strand fiberglass mat...poly resined it...and placed it up under the hull where the "drain" hole was it was about a 1/4' hole thru the hull..going straight down...not out back like normal!...anyways...used an old garbage can and some other stuff to hold the new fiberglass patch flat and tight to the hull
used fiberglass patch up to fix a couple chips and dings while I was in the area.....sanded all that faired out nice! cleaned area with acetone...
put the gel coat on my "day before" repairs today too......double coat...then waxed it with turtle wax after it got tacky...didnt have the PVA mold release WHOOPS!...hardened up fine though....still hafta sand it, polish and wax it...
heading to the lake today (after I go to bed and wake up it is 2am), might be one of the last few times for swimming this season, supposed to get alot cooler next week..should be 100deg with 80 deg water atleast...SWEEEEEET maybye catch a few fish too!
cant say too many times that the poli glow gel coat restorer worked like a champ...check out the video if you havent...on my earlier posts...shows how good it works...we will see how long and good it lasts next....we already waxed it event though ya don't hafta...real slick now!
looking at LED lighting for the main areas in the boat....low draw...use LEDs in our RV and can last forever on battery.....I like alot of light...on demand...
nothing worse than a dark deck and cant find something...thinking RED leds on this project..not sure...Ill post some pics in the AM over cofee...too pooped out to do that now...CHEERS!
will post pics in AM
