Re: PROJECT ~ JEZABEL 23' Sleekcraft Executive ~ CHECKLIST UPDATE
Well, heres the TO DO list...............I'll double post this on the 1rst posting of this thread maybye later...and check em off as completed!. Last update MAY 28th 2010 11:40am PST
Must Do's or WANT to do's - GREEN indicates complete...Red needs to be done! before sea trials.............. Yellow is work in progress
BILGE / ENGINE
Clean and re-paint engine, polish chrome and exhaust
COMPLETED
Replace all rubber hoses on engine COMPLETED
Compression test engine add marvel mystery oil to each cylinder before startup, replace spark plugs
COMPLETED
Rebuild carb...adjust carb COMPLETED
Check ignition timing <
completed runs like a top>
BILGE - fix holes that we drilled to air out the pinhole leak in the frt of the bilge separator plate (frt of bilge)
COMPLETED
BILGE - remove prev owner installed jerry rigged drain hole ...will post pic of that one! also found a screw blocking a hole, fixed that while in there (back of transom)
COMPLETED
BILGE - add second NEW bilge pump <may not do that>
BILGE - replace old bilge pump hose it is swellled a bit...
COMPLETED but with a snag!
BILGE Install new bilge exit port (3/4") prev owner had 3/4 inch hose clamped down onto 1/2" fitting! nice having bilge water come back ini the boat when it leaks eh?
COMPLETED drilled bigger hole...replaced bilge exit port with 3/4" new fitting
BILGE - old bilge pump clean and test (it's the cartridge kind and is epoxied in) -
COMPLETED / WORKS
BILGE - Gel coat entire bilge area! or paint it since we started doing that.
COMPLETED (painted it aluminum)
BILGE - oil bilge blower and re-test or REPLACE bilge blower
COMPLETED replaced with new atwood inline turbo
Clean out fuel tanks and remove clean and reinstall fuel pickup tubes <COMPLETED>
Replace fuel filters/water separator/carb ffuel filter and add a throwaway fuel filter to fuel line....<
COMPLETED>
STERNDRIVE
Sterndrive - Test trim/lift hydraulics -
COMPLETE / WORKS but has leak!
Sterndrive - Found leak at port trim cylinder! need a reseal kit or replace BOTH cylinders I will check it off = once I look into it or fix it<>
Sterndrive - Order NEW upper housing, Starboard trim sensor, orings & gaskets & recieve parts -
COMPLETED
Sterndrive - Replace upper housing, inspect guts, replace seals, re-assemble upper unit, mate to lower unit -
COMPLETED
Sterndrive - Strip and paint sterndrive and transom plate, gimbal Chrysler White! the ol' WHITE ANCHOR!!!! lol
COMPLETED
outdrive is painted and installed!COMPLETED
[COLOR="Dark Orange"][/COLOR] Replace on trim sensor and install adjust both <We got the new sensor installed...have to add some special orings to seal em up and adjust em yet...TODAY>
Test outdrive and make sure sea water pump works and outdrive clanks into fwd and reverse ok <
COMPLETED>
INTERIOR
Strip out old interior[/B] and chocolate colored carpeting BARF!!
COMPLETED
Manufacture new captains seat base / cooler stowage
COMPLETED
Cover new seat base with scrap vinyl from prev project, paint with tan vinyl paint
COMPLETED
Engine box / jump seats Recover vinyl as needed, paint to match using vinyl paint
COMPLETED
Engine box / jump seats Install into boat / bolt in place
COMPLETED
go out and eat mexican food [/B]in celebration of interior work done YEA!
COMPLETED
Install stereo and speakers, custom stereo enclosre etc...test out with AC/DC music <COMPLETED>
TRAILER
Replace blown tire <COMPLETED new to us used tires and rims (white ones)
COMPLETED>
Replace both brake cylinder actuators<COMPLETED>
adjust trailer brakes and test... <
COMPLETED>
Grease and inspect all wheel bearings <
REPLACED all bearings and seals, new races>
Replace all wheel seals <
COMPLETED>
add bearing buddies <Decided bearing buddies are not the way to go...deleted bearing buddies and added new caps
COMPLETED>
Check trailer brake pads <sandblasted the hubs and brake drum/backing plate and repainted refurbished
COMPLETED>
Double check trailer lighting <replaced one bad light....tested out
COMPLETED>
Fabricate spare tire holder and install spare <
COMPLETED>
[COLOR="Dark Orange"][/COLOR] Fabricate a bow stop and add a winch <got the parts now I just gotta fab em in and weld it up....>
fabricate or buy and install some trailer guide ons <>
COSMETICS
Poli-glow gelcoat restore the entire hull -
COMPLETEDbut updated...we strippe dthe popliglow and wet sanded & power polished the upper deck looks WAY better now
Make wood lattice for deck drop down area (I want a flat deck)
COMPLETED
Clean/Polish trailer wheels <
COMPLETED >
Prep / Prime / Paint the whole trailer! <Got the paint the other day!>
Replace Bunk Carpeting <over the summer we will do this>
Repair a couple exterior gel coat chips and dings near transom
COMPLETED
<work in progress repaired all the dings and scrapes, holes....faired it all in ..have to sand the new gel coat down and polish it> completed
LEGAL STUFF
DMV title for trailer / out of state inspection of trailer / license plate <COMPLETED>
DOW boat title and tag <
COMPLETED>
BOAT TAGS = Lake Mead Natl Rec area FEE AREA! need the OTHER tag for the boat <
COMPLETED>
make sure all safety equipment on board <COMPLETED>
TEST HER OUT on the water! <
THIS WEEKEND!>
