Re: Poor Man's Skiboat...Restore?
Well tonight I got in the boat and actually felt good about the way it is turning out.
I painted the trailer black
cut off the side pads
and put the boat back on the trailer
The cap is waiting to be sanded down with 150, cleaned and painted. The cap is 100% stripped, nothing but fiberglass and almost all old button holes filled and sanded.
Here are some pictures of where the project sits now. I SO cannot wait to get into the mechanicals/electrical.
I also picked up another 3 gallons of resin which puts me at 16 gallons so far. I don't think I will need it all, but you never know.
The transom needs to be hit with 150 cleaned and painted. See my new pretty ski tow? It is huge at 3" diameter and 304 stainless.
Side of the boat. I started wet sanding one side and will have to recoat both sides of the boat as the brown is showing through. I think I painted when it was too cold as the paint isn't as smooth as I wanted, but it does look great from 3 feet away. (before the wet sanding) Notice no more side bunks on the trailer.
Here is the cap, everything is yellow due to the lighting, I still have some glue to remove off the bottom of the dash, but that shouldn't take long.
and the bilge. This looks much better in person. I have the bilgekote just waiting for the time to paint.
Thank you guys for the kind words. I have so much going on now, need to get back into shape for some spring bike rides, vacation, house needs repairs, but the boat seems to be taking up most of my time. Going this summer without a boat is NOT an option and I am under a deadline. I hate doing project under time constraints...this is suppose to be fun. My next one will NOT be forced because I will have the P.M.Sb I guess I was just feeling guilty because I wasn't working on the boat enough and I usually do an hour a night on it plus 4 or more hours on the weekend.
Then I have the other worries:
Did I seal the outdrive bellows properly?
Is the shift cable going to work?
Is the crack in my outdrive an issue (wasn't all last summer)?
Is the motor going to work?
yada yada yada... One step at a time.
