This is just a thought. You may want to try and align your windshield before you screw down your consoles.
Thanks. I was actually smart enough to consider that. That and the bow seat support piece lined up before a single screw is put in my deck. I’m not sure I’ll commit to all the screws it originally had for now.
Im undecided if I’m going to raise the bow / casting deck starting at the consoles or have it U shaped allowing you to stand between the consoles. In rough water, standing there helps.
I will either put the rod locker under the bow deck if I bring it back to the consoles, or I might put 2 lockers along the sides. I was looking at the styrofoam pieces that go above the deck, and I think I’m not going to put any of it back in. I don’t even understand why they put some under the gunnels. If you need buoyancy there, then your already sunk.
I fit the rub rail strips back in, and the bow bumper cap. If anyone else is dumb enough to remove them like me, or you need to replace them, they do slide in. I had a couple small dents in the channel that pinched the strips. Which is why they wouldn’t slide out for me. I fixed the dent by using a flat head and pliers to open the slot it slides through. Add some WD-40 to the strips with a cloth, or whatever lube you want, so they go in easier.
I also cut 4 pieces of 2x6 at 11” and screwed 2 on top of 2 so they form an 11”x11” square and then hole sawed my 3 3/4” holes for my seat bases. This way I can sit in the seat and know exactly where the base should be. I’ll make up another so I can put a front and rear seat in and judge the space between them. I want the windshield and throttle lever in before I commit to a spot. So the seats will likely be the last thing to go in.
Well, back at er. I put the second (partially 3rd) coat of paint on the trailer, so I can start putting that back together tomorrow or the day after.
