pic of work so far
jcsercsa
Re: pic of work so far
here are a few more just for good measure !! lol there still the bow are !!
this last one in this set is just the area i am working in !!
jcsercsa
hate to tell you this buddie but that wax on the floor isn't needed yet :D
HAHAHAHA sorry i missed this Neil !!! hahaha It not a wax its a buffing compound , to take the wax off !! I just hit a spot to see what it would do !!! I was trying to clean some of the dirt off , man it sure made it shine !!! lol
well I am getting on her today got to make some blocks to raise it up some !! at least 6 inch so i can get me and the Dollie under there !!
and i think the rub rail is coming off, I got a couple more hour of grinding the spiders out !!
And also got to drain my turbo heater , she kick on and goes right out , changed the spark plug last week , and that didnt fix it , she is sparking all the time and the spray is going good , so it got to be the gas !!
Ok well i think its nap time , more later !! john
oops!
how do you like working with the marine tex john?
its looking good.....just a little more time and your done!
have you tryed to sand down any the marine tex yet?.....if you take a sanding block.......longer than the repair area.....and youve filled the area higher than the surrounding surfaces.........you will get it flat as factory in no time..........if you need to fill more....go ahead....remember to clean with aceitone.........the key to a perfect boat is the prep.
jcsercsa
Hay Bud,
the marine -tex isn't that bad , last week when i work it in some of the spiders that i ground out , I made a bunch of it and 30 min, later it was still workable , the temp was in the upper 50's so that helped a lot , I didn't care how long it took to harden, cause i wasn't going to sand till today !!
and sanding it isn't that bad either , it a little harder the the gel-coat , and i am cheating , I am using a parallel that is hardened steel , useing the sharp edge and scraping it frist !!! man is it cutting down on the grinding !!! am it is pertty smooth even before i grind !!
So i did get some boards cut to fit under the jack stands , got it up about another 4 inchs !! I am going to try it there !!
While i was under there , i was looking at the keel [ the bottom of the center deep v ] and there is some wear under there not to bad but down to the glass !! I am going to have to build it up with the marine tex !! i was looking at them keel gaurds before , i think I will put one one her !!! Other then that , there is just the one gouge that i did with the trailor !! and that is only a little over a inch !! the rest under there looks really good !! except right under the transom there is a spot that i really didnt get a good look at yet !!
I didnt get the rub rail off , and i didnt get a nap in eather , went to lay down and the school called my middle one was pucking !! so had to go get her !!! my poor Baby !! and so that shot the nap !!! &&^%$%$&^&&*(((^^ lol I got tomorrow off tooo so we will see how far i get on her tomorrow , and i will get some pics also up tomorrow !! John
oops!
life......it has a way of getting in the way of boat building !:D
jcsercsa
Ok guys and gals , well theres not a lot to show , I did get a second coat of marine tex on some of the spots that i got sanded, and got some other spots filled for the frist time !!
this frist pic is just the transom raised up and the second coat put on !!!
this nest pic is where the butt crack was and there was some spiders in the little ledge is !!
before
this next pic is before the scraping
and after
jcsercsa
Ok here is a few more .
this is the straboard side , the second coat of marine tex
before scrape and sanding , frist coat
I am missing the pics on the keel and the gouge that i was talking about , i did get the gouge filled with the frist coat !! I will get them tomorrow !!
and as you can tell the rub rail is still on , and some where up there I said that a couple more hours of grinding . well there stil a couple days of grinding to do before I can fill them with marine tex !! john
oops!
uh.....johnny.....theres somthin wrong with your sig champ.
there is just a bunch of red numbers......
the dead things havent won that many times have they.....:D :D :D
oops!
p.s.
i noticed there is no numbers when the REAL oilers were togeather ???? :D
jcsercsa
DEAD THINGS ?????????? HOW MANY have you guys won ?????? hahahaha DEAD things *** ####@@#@# lol are we jealous LOL
oops!
wow......hmmmmmm i checked the records.......detroit didnt win the cup in those years....BUT....they were in possesion of the cup......:confused:
one can only assume lord stanleys mug bounced off the truck and hit the captain in the head before landing in a wingers hands all those years
jcsercsa
OHH reread the records, It just they didnt have any compitation and they just handed it to us knowing we were the best !!!! lol
And i see you didnt look and see how MANY you guys Won ????? lol
Ohh there was this one guy you had , wasnt it frezety metzty, something like that , he wasnt to bad , but wasnt the some talk about steroids useage ?? or something like that ??? hahahahhaahahhaha John
jcsercsa
hahaha what no come back buddie ??? couldnt handle the truth?? lol John
PS hay I could send you a jersey of the best team [ red and white ] lol
PSS like you said alls fair in love and hockey !! hahahah
jcsercsa
Hi all , will let oops stew on that last post for a bit !!! LOL
Ok its my sat, again !! time to get on the boat !! I am going to take some pic of the keel and get them up tonight !! then it grinding time !! I am hopeing that i can get all the spiders and any thing else ground out today !! and have to get the rub rail off !! then its marine tex time again !! John
jcsercsa
Ok here are the pics i promised !!! this frist pics is a third of the way back on the keel , its right where she would hit the sand !! it wasn't me got her this way !!
this next pic is the back end of the keel , not a lot here just some scratches i have to get out !!!
this next pic is some gouges that are under there ,
jcsercsa
here are a few more !!
this pic is one of the two spiders
then the second spider
another of the keel looks toward the stern
this is before i was grinding down there
I got the keel ground down in the last pic
and also got some marine tex add
and got a lot of the top marine texed
also ground all most of the spiders out
found a few more i will hit tomorrow !! John
jcsercsa
Hay all , didnt get a lot done on her today !1 did fix a spots on the transom . Where i clamped the motor mounts crack the glass , so i ground out two slits about 4 inchs above the spots where the clamps sit. I mixed up some epoxy and poured it in there , before that I duct taped under there so it wouldnt leak out , then poured it in !! it still leaked , not much then when it set , i mixed another batch and pryed the slots open again shoved a bunch of glass in there after i weted it out and then poured some more epoxy in there !!! Its not going anywhere now !! I will post some pics later!!
Did get a little more grinding done and scraped some of the really high spots on the marine tex !!
Other then that , had a buddie call and said he need help with a doe !! so that shot 3 hours !! when he said he need help , it ment you you cut him up for me !!! lol lucky he is my best friend !!! lol John
jcsercsa
Man i went to get the pics I just down loaded from the camera and there not there , and of coarse I deleted them after i down loaded them , so i will get somemore tomorrow !! John
