My 1994 wellcraft eclipse 210s overhull.
ezmobee
Re: My 1994 wellcraft eclipse 210s overhull.
Looking very nice.
94eclipse
Got the bottom end together today and laid the second coat of glass down on the floor.
Here is the motor.
The floor
boatnut74
Looking good, your moving along quickly. It sure helped most of the teardown was done prior to purchase.
94eclipse
No the boat was still all there just never took thepic. Only half the floor was removed
produceguy
Nice job.
For 800 you got a smokin deal. Really like the style of your boat, really classy.
Hustler04
Thanks can't wait till I'm done so I can have my life back and enjoy the boat.
I know that feeling, atleast my wife does all i hear is about the time and money. But i have never had the enjoyment that i am restoring my boat. It looks great.
94eclipse
Well today I removed all the bellows and fought with the shifted cable for about 2 hours till I cut it and drilled it out. Also got one seat base done and the other one cut but then it started to rain. So I went inside and started torquing the motor and messed up and tightened two bolts two 60lbs so now I need two new rod bolts.
94eclipse
Feels like nothing is getting done. I'm just happy the hurricane isn't coming to me.
Here is a pic of the last coat of resin after grinding the imperfections.
Here is the boat after a little quick wash
And here is a BBC milled down to work with the sbc
a1999ponyboy
quick question? are you useing marine plywood? and is that an alpha or bravo out drive? i ask because i just bought an 89 raven 2100 bow riderand the floor is soft in the back of the boat, and it looks like im going to be doing the same thing!
ps i know nothing about boats except how to drive them lol
94eclipse
i used exterior grade wood for the stringers and sanded wood for the floor. i have an alpha one gen 2. got alot done this weekend. installed gimbal housing with all new parts and cable, and put the motor in.here are some pics. hope to have the engine bolted down tonight.
WILSONS88
Nice engine lift!
oops!
nice job so far bud.
you really scored on this boat...the trailer is worth 1500 alone.
is that where the gas tank was?....normally that was the ski locker and the tank is aft.
and where do you boat?.......the reason is....why do you need a heat exchanger?.....is this going to be a salt boat?
94eclipse
Yes its a very good engine lift,no effort needed.Gas tank is infront of the engine. The little port hole is where the door goes for the sender. And I live in Miami, nothing but salt water here.
94eclipse
This is how the engine sits now new starter,alt.,water pump, and power steering. Intake and valve covers are still loose because I just finished adjusting the rockers.my main focus was to get the acc. Drives done to see where the heat exchanger can go to make the mounts. Also ordered the raiser block off gasket and new thermostat housing.
produceguy
Nice job!!!
Looks really sharp.
94eclipse
Got all the engine harness done and git it running half ads. I think the timing is off alittle. also got the holes in the transom. And also ran the exhaust pipes but need two more downpipes from the y pipes.
parrisw
Ensign
Nice work. comming along nicely.
94eclipse
Been getting a lot of little things done. Git the trim tabs finally working. Also had to replace the new Fp because it cracked.
Here is a video of if running and a pic at the gas station.....going for a test ride this weekend.
