My 1968 Glastron GT160 rebuild......
ahmincha
Re: My 1968 Glastron GT160 rebuild......
Same ones I use cojen. But harbor freight sells the rollers 6 pack for 6 something looking great
Corjen1
Thanks or the Tip!!! Guess Ill be at harbor freight tomorrow!!!! Need to get some all thread to make some clamps also!!! That transom is going in this weekend!!!
archbuilder
Looking forward to seeing that transom in!
Corjen1
Arch,Me too!!! for me, thats a milestone, the beginning of assembly!!!! Feels like down hilll from there....
Corjen1
Beginning of the Reassembly today!!!!!! Started off today by building a set of clamps for the transom. got 2, 3 foot pieces of all thread, nuts and fender washers to make the bolts. Cut them in 12 in sections and welded the nut to the end of the all thread pieces. (making a 12 in bolt, 6 each)
I kind of took WOG's idea with his clamps and modified it a bit, I didnt want to mess with that many pieces (clamps, bolts /nuts and a gooey transom all at the same time) Here, put the operation of chop sticks in you brain.....it was my idea and may help you follow my thought path........
Made 2 clamps with a 12 inch throat and 2 with an 18 inch throat. I wanted to be able to reach to the far corners of the transom, the hull kind of flares out and aft on the outer 12 inches . I glued a 3 inch block to one side of the clamp, above the bolt. ( 3 inches because that is wider than the transom and hull together, serves as a pivot point for the clamp) In this pix show what Im saying....
Here is the dry fit, too get it all lined up and the clamps a slip/snug fit. I didnt want to dink around messing with them when the PB was kicking.....
More to come....
Corjen1
Ok this is my first shot at PB, Im sure it wil fit the bill, but I have some questions......
4 buckets, 500 ml of resin....
I measured the chop strands and Cabosil, very much like I measure the seasonings when I smoke a brisket......started with 2 of these and added from there to get the consistency I wanted. I would guess that I ended p with a bit more that a half cup of chop per bucket
I used approx a cup and 1/3rd of cabosil to make warm/runny peanut butter like consistency for 500 ml. 20/20 hind sight, I should have used more I think.... If you havent used this before, make damn sure you use a respirator ad gloves when handling it it is a super fine dust of ground glass beads. Absolutely will get in your lungs and embed in your skin....
After I got it mixed completely, I added the catalyst.....Im positive if I had done it before mixing in the ingredients, I would have ran out of time....
Question...... when I was mixing, it seemed that after the cabosil was completely mixed in, the chop was wanting to ball up, should I have cut and shredded into finer pieces ( like maybe 1/4 in max?) it wasn't as uniformly distributed through the mix as I have seen in others pictures. When I spread it, i assisted in breaking up the larger clumps of chop and spread them all over.
More to come....
ahmincha
Corjen I first mixed in my chopped then I mixed in the mekp stirred till I thought It was thoroughly mixed then added my cabisol. I got that balling effect when I put in to much chopped
Corjen1
OK, final product....
I will need to go back and re-pb to better the fillets and fill in spots as needed, ( this was done from squeeze out) also install the PVC tube to go from bilge drain area to the outside skin. but over all I an pretty happy with the install!!!
The PB has already kicked, but I think I will leave the clamps on for at least 48 hours
Thats it for today, and this weekend. Will be kissing up to the wife tomorrow for putting up with mine and the kids crap for another year!!!
Have a good weekend All!!!
Corjen1
ahmincha
Feels good to have it in. Looks good to
Woodonglass
Yep chop your fibers a LOT smaller. What you made is what I call Tiger Hair. Very structural but hard to spread! Use scissors and cut the fibers into 1/4" small chunks for PB glue. About 1/4 cup of fibers per quart of resin
Corjen1
OK, now that the site is up and running, here is the progress from last weekend.....
PB's in the bilge drain tube
I used the frosting funnel method.....worked great!!!!
More to come
Corjen1
Transom and bow floor are all PB'd in also.....the 1/4 inch chop work WAY better!!
It was a bit cool here last weekend..60's for the high 95 today.....:facepalm: I had to put a little heat to the transom. I just kept turning it on and off to maintain temp for a few hors
More to come....
Corjen1
installed the water drains also...... I put 3 each on the stringers and 2 on the bulkhead.
I ground out the coves like this, using a 90 deg datco with a grinding bit.....
PB'd the pvc pieces in......I left them long and sanded then down after it cured.
After all that cured, I did get first layer of 4 inch 1708 tabbing on bot the bow floor and the transom. I still need to get those pix uploaded. I know...no pix, not true.....so maybe I did, maybe I didnt....
Woodonglass
Yup, That PB looks Really good!!! Nice job on the Drains.
Heck a few more sessions and You'll be ready to "Hire Out"!!!:D
ahmincha
Looks great My first batch of pb I added way to much chopped strand live and learn
Corjen1
Seems like I lost a few posts and a page......hmmm....
Update.....nevermind, I see the notification of lost pages now.......guess ill repost progress!!!
Corjen1
Site is not letting me post pix......ill try again later.
