lundnisswa
Thread starter- Joined
- Mar 2, 2008
- 245
Re: Lund Nisswa Restoration
Oops, Thanks for filling me in on the vertical lines of the 1708.
In those pictures, I had done alot of sanding/grinding toward the tops on all of the stringers except the inboards on the inboard sides 8 feet from the Transom, that was the last section I had to do that was done today.
I had been cutting across the roll, 50" pieces and then cutting the size I need. I wish I would have known at some point prior to doing these four stringers and Transom.
Either way, it is only the very tops that need ground off, and luckily I had capped these with 8 oz prior to installing them.
So will try this technique on the next lay-up.........Live and learn.
Thank you
Lund
Thank you
Lund
