Re: hull extension in progress with picks
heh heh heh........i fell asleep at the computer posting a pic of a vaccume.....
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
......lol
ok....im awake....
i had to re vaccume the hull because once its sealed......if the under deck isnt clean.....you will allways have a dusty boat.....i was considering leaving a beer cap in there....but ....nawwwww.
the white spots in the air is dust flying around.
well thats when murphy showed up....i fought with him for a few hours.....i bought a 1 1/4 hole saw....so i could install the drains in te coolers and mount the coolers........
well the drill bit on the whole saw wasnt a 3/8ths bit...!.....i needed that hole saw....and it was too late, the store had allready closed....so i had to come up with somthing......
an 11 ml socket with a 1/4 inch drive.......a 8 inch 1/4 extension.....and i cut the drive end off a 1/4 inch hand held driver.....what a pita finding all that stuff.
but it worked......and the coolers went in....along with the drains to the bilge.
in this pic....you can see the drains.....to seal them....i just used pl.construction adheasive.
i also had a ton of grinding to do on the various peices for the deck....so i cleaned up the edges of everything.....tommorow.....ill be working on cutting out the ski locker and the cooler ....and glassing in the frames.
cheers
oops
