Re: hull extension in progress with picks
what? ....besides clean out the shop?...
the motor mounts need to be cut to legnth, and fiberglassed in....
then the boat will go to the mechanics to have the motor installed......
when that happens, the transom is going to be a major issue.....as the transom is waaaaayyy too thick for a conventional set up......
not only is it too thick.....it is not the same thickness in all areas of the transom.....and the t plate needs to be of set strict tollerances....
so cutting out the hole for the out drive will be a real pita.......
onced the hole is cut....ill use a router set a depth to flange to inside edge to thickness.
after the motor is in.....and water tryals prove a failure or sucessful.....the interior will be started on.
most of the interior, is an easy thing to do.....just fabbing some benches out of fiberglass.....
the dash board....is a different story....i really dont know how to do that....as i have to sculpt the shape out of foam.....then glass the shape....then gellcoat that.....so that project will be a month or two in the making.....
there is still lots to do on the boat.....it is by no means finished.....but a major phase is now complete
