Re: Funny "TLC needed" boat ads on Craigslist.
This is a great deal if you don't mind that it doesn't run and the lower unit is cracked.
http://muncie.craigslist.org/boa/1879721345.html
85 baretta ski boat with MANY extra. TRADE FOR BOAT WITH OUTBOARD - $1500 (Albany, IN)
Date: 2010-08-04, 12:43AM EDT
Reply to:
sale-nha7k-1879721345@craigslist.org [Errors when replying to ads?]
I have a 1985 Baretta fish and ski boat.. it has a 4 cylinder 140 hp inboard mercruiser motor with an alpha 1 sterndrive with an aftermarket fin The exhaust port on the outdrive had a small crack so the marina put some putty on it to fix it, i was told that it was no big deal. The outdrive was pressure tested and was good with no leaks. I have replaced many parts on the boat and have many many extra replacement parts for later. also included with the boat is a one person boat tube and brand new line. The interior is in decent shape the seats were ripped and they were zipped tied back together but they work Seats are easy to come by and can be replaced if wanted. the seat on the post in front of the boat removes to make seating. It has a trolling motor plug and switch in the front to install a trolling motor. The boat is a little dirty and could use a nice bath. The boat runs and drives but lately will not stay running, believe to needing carburator adjustment and or timed due to a new distributor was installed, it gets fuel, air, and spark the carb just needs fine tuned The fuel reaches into the inlet of the carburator but i cannot see it jet fuel into the carb. I was told it was an inlet filter and a very cheap easy fix. easy stuff to get this water ready withen a hour or two. also have an extra complete carb to come with it. I have many many extra parts to go with, this is a great deal dont pass it up. NO LOW BALL OFFERS. clean titles on 1978 trailer and 1985 boat. TRADE STRAIGHT UP FOR BOAT WITH RUNNING OUTBOARD MOTOR.. YOUR TRADE DOES NOT HAVE TO BE PERFECT BUT IT NEEDS TO BE RUNNING GOOD. COSMETICS ARE NOT AN ISSUE.
WILL ALSO CONSIDER ANY TRADES EMAIL OR TEXT YOUR TRADE OFFERS.
I have replaced the following parts withen 2 weeks and have ZERO hours on them.
Brand new bellow replacement
Brand New gimble bearing
rebuilt sterndrive
New livewell plugs
new sterndrive gasket and seals
Brand new spark plugs
new rebuilt distributor
I also have many extra parts that match this boat and motor exactly
Extra complete alpha 1 sterndrive
Extra fuel pump
Extra Carburator
Extra distributor, cap, button, and wires
Extra motor mounts
Extra oil pan
Extra bilge pump
Extra blower
Extra docking bouys
Extra Hydrolic pump and
Extra Ignition coil
Perko duel battery switch
plus many other misc parts
TRADE FOR BOAT WITH RUNNING OUTBOARD MOTOR. YOUR TRADE DOES NOT HAVE TO BE PERFECT BUT NEEDS TO RUN PROPERLY. COSMETICS NOT AN ISSUE. LOOKING FOR ANY OUTBOARD SUCH AS BAYLINER ETC..... MY BOAT IS NOT PERFECT BUT A LITTLE TLC AND A LITTLE TINKERING WILL HAVE IT WATER READY BY A DAY, DO NOT EXPECT A PERFECT BOAT. I HAVE INCLUDED HIGH RESOLUTION PICS FOR EASIER VIEWING.
CONSIDER ALL TRADES EMAIL OR TEXT ALL TRADES
CALL TEXT OR EMAIL ANYTIME
