Fuel pump no power/ relay to pump help
Fun Times
My 1998 Volvo powered boat has a lanyard. I always thought it was required by law on boats going back to the mid 80's at least.
The laws on making one use the lanyard as mandatory are still up in the air expect for Alabama.
Looks like it became a requirement for boat manufacturers to "install" them in 06.
1-4 April 2006 NBSAC passed Resolution Number 2006-77-02 (Boat Builder Engine Cut-off Switch Installation Requirement) and Resolution 2006-77-4 (Required Use of Engine Cut-off Switch Link).
If interested, Here's a pretty good rundown of the history of the lanyard switch mostly starting in late 1973 for a patented recreational boat use.....Scroll down a bit for the timeframe rundown history. http://www.propellersafety.com/3913/regulations/kill-switch-history/
flyhigh123
got to thinking, i wonder if the ignition switch died on me.... maybe the on position is dead...
Fun Times
That was one of my first thoughts when you mentioned it would run while holding the key over to start in post 54. Try jumping the wires behind the key switch to see if it helps. Connect Red to Purple then touch Yellow/Red to Red till started and release.
flyhigh123
Will go today. Read the manual and it also gives advice on checking the ignition switch. Will check continutity for both points. After that, i will jump the wires and see. Boat goes to shop on Monday, so hopefully i can solve this before hand.
bruceb58
Don't measure continuity. You have to take wires off to do that. Just measure the voltage.
flyhigh123
Update:
Ignition seems ok. Continuity check seems to work for key switch. It didnt read zero, but read around 100 for ON position.
I did jump a 12V source from POS on alternator directly to the bunch of wires which includes the green wire and the engine fired up and ran . So it seems the issue now is somewhere between the ignition to bunch of wires/ alternator.
I also got the alternator in today from iboats. Is the alternator something straight forward for install? If I were to put it in myself, can you guys help suggest which color goes to which letter.
The back of the alternator has the following letters:
L2
P
E ( bottom Right)
EXC
S
B ( letter under the black wire upper left)
I have the following wires:
Orange ( this is 12V)
Red/purple
Red
Purple/White
Black
Green
Assuming the diagram is correct I have the following:
Orange->P
Red/Purple -> S
Red-> ExC
Purple/White ->?
Black->Ground ( is the ground the peg between B and E or is it B?
Green-> L2
Let me know if this is correct and what I'm missing.
Thanks!
bruceb58
You don't have it correct.
It should be:
B is the wire that goes to the battery(Thick Orange)
P is the AC tap and that goes to the choke(Purple/White)
E is ground(Black)
EXC and S should be tied together and that goes to your ignition switch(purple or red/purple)
L2 goes to the Fuel Pump relay(Green)
You may have to make up a jumper to connect the excite(EXC) and the Sense(S). Don't run until you get those 2 jumpered or you will fry your new alternator.
Look at fun times picture in post#3. Even though it is not an OEM picture it's basically correct.
flyhigh123
It should be:
E is ground(Black)
The Red is the jumper for the EXC and S. Thanks for the clarification. The alternator didnt come with any manual.
bruceb58
I have no idea why you have both a red and a red/purple wire. You may want to investigate which one gets voltage on it with the ignition both in the on position and off.
EDIT: Just saw your post.
flyhigh123
Per the diagram, i think that it is correct. Red Goes from EXC to S and Purple goes to S. Its just 2 cables, but the S terminal has 2 wires.
flyhigh123
put in the alternator. looks really nice and feels good to have all the wires go to the correct location. However, didnt fix issue. Boat still will not idle in On position, it will idle in Start position.
Waiting for room at the mechanic. Tomorrow i will meter the 12v at ignition switch.
bruceb58
Just with the ignition key on, and doesn't matter if engine not running, it should be 12V. Basically, if you get 12V at your ignition switch, you should get 12V at the excite.
flyhigh123
Tested the Ignition key at ON, it read 12V.
Went to the Excite with key ON, and it read 0V.
The problem seems to be somewhere in between. What would you suggest the next step be? Can I run a new wire from the ignition to Alternator?
bruceb58
Are you absolutely positive you don't have a man overboard switch somewhere?
Try following the wire leaving the ignition switch and see how far you get with it. Maybe it goes back to your fuse panel and picks up another fuse.
Make sure your engine connector is fully engaged. You can also pull apart the engine connector and see if you get voltage there.
Fun Times
Try ohms checking the purple wire from the key switch to the Alternator purple wire and see what you get...Next you have a main wiring harness cannon plug connector at the engine, remove and inspect the pins on both sides.
With the meter still connected to the purple wire at the key, ohms check all the wires at the boat side plug to ensure you get a good ohms reading to only one of the wires. Now ohms check the wire between the engine harness plug to the purple wire at the Alternator. The purple wire pin harness should be pin number 5 like seen in post number 3. Also be sure to wiggle the harness as it could be a bad connection inside the plug somewhere.
Bringing the diagram over here so it's easier to see vs post #3.
flyhigh123
Yes no man overbaord switch.
flyhigh123
Is the "main wiring harness cannon plug connector at the engine" the Main Cable connector on the diagram? I have a black rectangular box which i'm assuming is the cable connector. I'll try what you are saying. Should i open the cable connector box and test from inside?
