bruceb58
- Mar 5, 2006
- 30,810
So is the fuel pump turning on? Without cranking the engine can you pump the throttle and see squirts of fuel in the carb throat?
Sometimes meters don't have enough voltage to turn on a diode. Does yours happen to have a diode selection? If so, it will measure the forward voltage of the diode. Your 470 measurement is because of the voltage drop of the diode. You will never measure 0 ohms across a diode. Your diodes sound good.
So what's the history of this engine? Has it ever run while you have owned it?
Disconnecting the alternator is not going to make a difference since the wire involved with the fuel pump can not be connected to it.
