Formula 27PC Transom Work
Status
Not open for further replies.
alldodge
Tank removal day, hoist setup
All that was holding it was on the starboard side bottom, and small area next to fuel fill
Seadoo stand works pretty well, had about a gallon left n the tank
The worst spot is where I my saw was to close to the edge, least at the weld it is thickest. Maybe some JB Weld before painting
All scraped off
tpenfield
Nice . . . Tank looks OK from afar, but you will want to give it a good close-up inspection for pits, etc. The paint certainly stuck well, which is probably why you had so much difficulty in getting the tank to come up out of the foam.
That saw cut along the side is a bummer. Hopefully, it will be OK.
What does the fuel bay look like now that it is opened up?
alldodge
Fuel bat looks good, next to no moisture at all. Appears the water was concentrated next to the engine side
Now some more bad news. The tank looks great all around except for the saw mark and the engine side. The pits are deep to my thinking. Depth gauge came up with .042 and .057. I will also say that the surface of the tank is not perfectly flat so variances are allowed. Figuring the tank is made from .125 (1/8) aluminum, there can be a spot or two which half the skin is gone.
Might be looking at a new tank
kcassells
Those are some lousy pitts you have there. I had some on my tank when I removed it. Tried to "patch" weld it with some of that new doo-hickey stuff out there but made the tank "bloat" expand where the heat was applied. At the end of the day my salvage concern went towards safety so i'm into a new tank. Plastic or aluminum at this point. Whichever makes more sense.
I just did not want to have to dig the old tank back up after burying it to save a couple of bucks/safety.
Tail_Gunner
Looking around at that nice shop and well appointed at that....then there is the boat.....Hmmm have ever thought about going thru that tank removal again? I vote new tank.:ranger:...carry on.
tpenfield
Check the tank label, if you have not done so already . . . it may be 0.190" thick aluminum (as my tank is). If it is only 0.125", then you are about 1/2 way through the metal.
alldodge
Tag was under some paint and it was manufactured in June 93, and thickness .125
Sure looks like new tank to me, sure don't want to spend the money but see no other safe way of doing it unless I find someone willing to weld, but then again, they don't put trailer hitches or luggage racks on a hurst
I would just replace the one skin. then again, I have access to a bunch of welders and material.
alldodge
Scott, Have all kinds of folks around here which weld aluminum, but none willing to do a gas tank.
kcasselle, Tail Gunner, Agree don't want to dig it back out ever, but will go aluminum to reduce the chance of leaking water down the side.
tpenfield
+1 for the new tank. How far away is Florida Marine Tanks factory?
alldodge
There now in Henderson NC
Looks like in the 2 weeks from last discussion the tank went up from 1096 to 1196, also to get the gray Ceramkote applied is an additional 200. So just sent authorization for 1396 and will be ready from 6 to 8 weeks
Tail_Gunner
Hold on 1400 for that tank are you serious? Do you know of any HVAC sheet metal guy's in your area???
tpenfield
The price seems pretty good to me, as long as it is an identical tank (AD - you should verify that they have the exact drawings, etc. There may be a reference number on the label of your existing tank).
The tank has several internal bulkheads, plus an internal vent line, and the fuel pickups are internally angled so that they can be located on the starboard side. So, lots of details going on inside that tank. Plus painted.
alldodge
FMT makes the tanks for Formula and the 27PC. Formula sent me the tank drawing and FMT sent me theirs and they are the same with only slight variations in layout. I would post but it's a PDF and the system doesn't like it. The tank has 6 fittings and all in the bottom right corner.
1-gas fill
1-vent
1-return
3-fuel pickups
  • 8083.pdf
Arawak
I'm curious, because I'm in the same "boat", so to speak... what are you planning to paint it with?
I have been looking at coal tar epoxy, but it's pretty pricey.
alldodge
Looks like now I'll just replace the tank. FMT will be painting it with Ceram-kote and is an epoxy and about 100 or so a gallon
http://ceram-kote.com/products/
Arawak
Interesting. I have been contemplating what to do about my tank. It has some minor pitting on the bottom, where it sat in the bilge, and two large-ish pits where someone left tape on it. It's not leaking and the inside is clean shiny metal, so I'm not really wanting to drop $500+ to replace it. I'd like to fill the two bigger pits and then coat it with something that will prevent water from contacting it again. It will go back into a sealed compartment as well... I was thinking about foaming it in place, but your experience is making me reconsider that :)
I am currently contemplating using epoxy to glass 6oz cloth onto the bottom and sides but will wait until after I'm done the stringers to decide.
tpenfield
There are some regulations and best practices when it comes to fuel tank installation, particularly aluminum tanks.
I will post some comments to your thread or send you a PM, so as not to distract from AllDodge's thread.
alldodge
As Ted mentioned there are USCG regulations for tank installation. The only reason my tank failed is because water got in. If you build it to where the water stays out there shouldn't be an issue. I'm planning on it going back in as it was so not and try to figure out if the tank is in correctly. My main issue will be sealing it.
Status
