Nice weather today, got me thinking about my boat. I finally got the hydraulic hoses and decided to install them. It really wasn’t a big deal, much easier that I was thinking. I removed the lines by pulling the manifold away from the gimbal housing, loosening the flare fittings, and pulling the hoses through the transom.
I removed the other 4 hoses from the manifold, and removed the manifold from the gimbal housing. I painted a little liquid Teflon on the threads of the flare fittings to prevent galling, then installed the two hoses into the manifold. I installed a new gasket. I fed the hoses through the transom into the bilge and worked the manifold onto the bolt studs. After all the connections were made and mounting nuts tight I worked air out of the lines by raising and lowering the drive.
I’m hoping these hoses last longer than one season.
