matthewp
Thread starter- Joined
- Jul 14, 2008
- 173
Re: aaaand so it begins - starcraft rebuild
Ugh! More bad news.
It turns out that my battery acid hypothesis is true. Last night I went one round with the shop vac and brush and got my first really good look at the hull. In both places where batteries were stored on the boat, there appears to be acid damage to the hull. It's not horrible, but not great, either. It has not corroded through, but some thickness has been "eaten" away. In both places, it's an irregular a pock mark adding up to about the size of your palm.
I've done some quick searching on the forum, and here is my first crack at a plan to deal with this.
1) neutralize with baking soda and clean thoroughly - thanks for that tip, Bob VT.
2) Use Marine Tex to build the thickness back up from the inside, overlapping onto the solid area surrounding the damage. Doesn't have to be pretty - it'll be under the deck
3) (maybe this is overkill), Rivet new aluminum over the patch - again from the inside) to add strength to the repair.
4) Gluvit the repair along with the rest of the seams and rivets.
I'll attach pics when I get back to it. Oh, and another question: Is there any reason I shouldn't use a power washer to clean out the hull? This may be an ignorant question - so feel free to treat it as such.
Thanks, everyone.
Ugh! More bad news.
Thanks, everyone.
