95 Sea Ray 230 Sundancer stringer repair
gmach
It's not too late to make this project an outboard conversion. :unsure: :LOL:
I thought about that too but, I bought a big ol swim platform to hang off the back though thats been sitting in the shipping crate this whole time. Plus this boat has a bad tendency to wander at low speed; do you think putting an outboard further out might make it worse?
gmach
Well it's been consistently in the 90's temperature wise here in California and so I have to work early in the morning or late in the evening...... until now.
gmach
Since the cabin is now air conditioned, I figured I would takle the rotten balsa core in the fore deck while enjoying the cool a/c.
gmach
I finally got around to glassing the transom. I really misjudged the radius I made for the steps on the transom. I figured a quater 1/4 inch round over would have worked but the 1708 did not agree and I spent a way to much time trying to get it stuck down and then watch it pop back up 15 minutes later. So instead of fighting it I just let it cure.
gmach
I ended up grinding out the delaminated corners and this time applying a generous fillet and laying down some new glass. The transom is 4 layers of 1708 and 5 layers of tabbing for a finished thickness of 2-1/4 inches and when I bang on the transom it has that beautiful solid high pitch ring!🙂
gmach
Here I am fitting the stringers in place. The Coosa is really easy to work with maybe even easier than wood. Because it is a dense type of foam, it can be sanded and cut very fast. One big drawback I found with it though is the dust it generates. I find that it irritates the skin way worse than normal fiberglass and it can work its way through thin clothing like a t shirt easily. I'm assuming this is due to the fact that it's less dense than normal fiberglass and the dust it creates is more coarse (bigger glass slivers).
tpenfield
Looks good. Keep in mind that Coosa is not as strong as plywood, so you will want to double up on the glassing of those stringers.
tpenfield
BTW - 1708 cloth yields about 0.045” thickness. So, the 4 layers on the transom are getting you 0.190” thickness (y)
