Re: 81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
Ok, so I am out of supplies, and out of energy. I got what I wanted to get done... DONE!!! The transom layup and stringer layup is finished. All I need to do now is test fit the drive. I need to come up with a rig that will help me drill the holes perfectly perpendicular to the hull.
Here is my plan.
I was thinking about putting down a layer of mat over the whole back end of this thing. If you look at the first of the thread I took out two huge flotation blocks that I am not going to put back at this time, as it really hinders the engine access, and I want to make sure everything is perfect. My thought was it has some structure reenforcement to it. So If I put down a layer of mat on the sides of the hull, will that not help with strength?
Anyway here are the pictures.
I decided to put in some drains at the back of the stringers just in case water gets back there. If you notice the glass is snug up against the stringer. NICE!
I then put in some little pieces of PVC after i put a ton of resin in the hole.
I also put down a layer of 24oz Woven as a final skin on the transom. Do i need more?
Is this enough?
I cut new floor pieces and glued them in.
I then put down two layers of CSM to cover everything up.
How do things look guys? I am REALLY happy about how things are coming.
