Re: 81 Glastron SX-190 Transom and Engine- PICS Galore Update 11-8
I did the same conversion on my Sea Ray 210.
The sterndrive is the same, pre-alpha 228 will work on a 350 fine. The drive can handle up to 300 hp, which you're not going to easily get on a non vortec V8 engine. If you upgrade to a newer engine the bell housing and drive won't fit, so for vortec your choice is basically to go for vortec heads and intake on the older block.
Engine upgrades for boats have been discussed a lot in the Mercruiser/volvo repair section. Adding 20 hp to a car makes a big difference, in a boat that may get you 2 mph (or not). Whatever you pick for parts, make sure it's got a truck like cam with good low end torque, that's where it matters the most in a boat.
You can buy a lot of upgrades for the 350 but the only one I've seen that you can really "Feel" is the vortec upgrade. Boats aren't cars, so putting in a stroker 383 or a hot cam, rockers, and fancy head porting won't get you much of anything worthwhile. If you want more power than a vortec 350 provides, go to a 454 or bigger.
Bear in mind that depending on your hull or loading, going to a hotter 350, a 383, or 454 will get you maybe 15 mph at most (for the 454). You can only go that fast in perfect conditions anyway, so unless you need to pull up a bunch of skiers or something, it's kind of a waste. Plus the drive won't handle more than 300 hp for very long, a bravo or volvo penta would do better.
I bought a reman marine 350 from Rapido Marine in Fla.. I'm happy with their product, price ($1728 with a performance marine cam) and the fit with my old hardware. Their aftersales support is good, too.
Erik
