Re: '79 Starcraft SS 16 restoration
Here's the port side panel...I don't like the look and I'm gonna level it off all the way across for more functionality.
They made them from the factory this way to match the helm since the controls bolt onto it, but I like using the entire shelf. I went 14" high on the panel, about an inch higher than previous.
I riveted in a couple more pieces of aluminum into the bow structure to make it more rigid. I acquired a bunch of material at a good price so I have plenty to work with.
I'm surprised how much gunk built up under those consoles in one season
Here's a shot of both side panels in test fitting. I got all the cables out, steering, throttle, shifting, main battery terminal etc. Getting ready to strip the flaky paint off and prep for a bit.
I also am happy that we got the transom pieces to fit. Not smoothly or anything, but good enough that I will go ahead and epoxy the wood now.
I bent the edge of the splashwell back some to make room, and the vertical gunwale supports had edges sticking out that were persuaded out of the way. A bit of a hassle but I'm glad everything fits.
