Re: '79 Starcraft SS 16 restoration
HA, Did you remove the dist. cap ? I had an 60hp Johnson that had the same symptoms. It would start and idle fine and take off pretty good but when I really put a load on it like towing a skier she'd bog and I'd have to back off a tad to smooth it out. Just a small hairline crack, replaced the cap and she was minty.
Just a thought if you haven't gone there yet.
Yeah I agree, it could have bad wiring and need a carb rebuild. We will find out eventually. I will get a thread going to get some more opinions before I spend any money.
We could just redo the wiring and use the harness that I have and we talked about it last night. The plugs are fine on it, it's just the wiring and connections that need to be all torn out and redone. That would certainly be cheaper than the brand-new kit.
