jasoutside
- Dec 20, 2009
- 13,269
Re: '79 Starcraft SS 16 restoration
Little bit closer
Little bit closer
Little bit closer
Sometimes it's tough getting a neat bead of 5200 on a long run like that, but it looks like you did a pretty good job. It takes some practice before 5200 becomes your friend. I had to touch up a lot of my 5200 applications with Q-tips, but I'm fussy that way.
Panel looks good the way it is, but do you need the angle along the bottom to stiffen it up at all? It will look good either way I think.
Looking good HA, I think LL is right the angle between the side panels and the floor really tie the two together structually.
As always sir beautiful work! As i read more and more threads and watch people redo their transoms and splashwells i feel as i should have tackled mine. Although upon inspection of bolt holes and so forth I could not find any soft or dark wood soo why is it that the closer to splash i get this funny feeling that there is something I screwed up somewhere that will inherently put me back in dry dock :facepalm: Oh well.. HA ur work is spot on! Keep up the good work bud! Still following
definitely install the angle. also i think think the panel would look nicer reversed so it was slanted in the opposite direction. thats just m though
Ha She looks great! Keep on Chuggin' and you'll be on the water before you know It!
The symmetry is not perfect but as a function over form type of person I am happy with the way it's looking.
We also got the cutting board routed out and bolted in place.
