Re: '77 Luhrs 28 ft. diesel repower - just beginning
Ahoy Bert!
Concerning the 6.2L:
An outfit called "Covington" was marinizing them in the '80's.
I had a 1986 version in a Tollycraft 26' for about 10 years ... it worked fine.
When I bought the boat in 1997, I called Covington and talked with one of the "old dudes" and got some info on the "marinization":
The word was that it was an "out of the box" truck version of the engine ... the Higher Horsepower "J-Code" model. If I remember right, the engine serial number will end in a "J". (The "C-Code" versions were lower HP.) Obviously marine Manifolds, Raw water pump, Heat Exchanger etc were added.
As you seem to know, both OSCO and Barr have made Manifolds for the 6.2L engine, MARINEMANIFOLD.COM still lists the OSCO under "Conversion Manifolds: Diesel engines"
Your earlier comment about the manual glow plug controller sounds good. Mine had a controller that would cycle the plugs on until the engine was warm, unfortunately the system sometimes held them on too long and the plugs failed prematurely.
It sounds like you know what you are doing .... I just wanted to confirm that the professionals have done EXACTLY the same thing with the 6.2 (J), and at least for me, it worked well.
FYI, mine had a "Twin Disc 502" (bulletproof) marine gear, but I recall that the Velvet Drive was also offered.
Good Luck!
Sam
Ahoy Bert!
Good Luck!
Sam
