Re: 1997 Starcraft Fishmaster 190CC Resto
Getting rid of that foam was a milestone.
I wire brushed around the seams and rivets and that Gluvit really got in there. The wire brush I used was made of relatively thick wire so nothing got trapped in there. Those green scrubbling pads work well too. You might be able to find a really stiff nylon or sythetic brush as well.
The wheel I used to scrub the adhesive off was made out of some kind of hard nylon/synthetic material and was like 5 bucks. Slap that on a drill and that will make shot work of that crud.
The last step before appying the Gluvit was to take it to a car wash and blast the he** out of the interior. You will probably have a hard time getting it to dry up in the cold before applying the Gluvit so a shop vac and a rub down with Acetone or something will work just as well. AS long as it's not greasy that Gluvit will go right over anything.
The first thing I did was buy a cover. I'm going to throw a tarp over my new cover
My previous owner did not believe in covering as well.
