Re: 1991 MonArk Legend 1800 FS
So, after the first run at the lake with the engine performing substandard I got into it yesterday and did some basic tests and adjustments.
I found I could lean it out but I couldn't get an over rich miss like I should have. After futzing with it for a couple of hours in the tub, besides being soaking wet from prop wash, I was pretty darn frustrated. It just kept getting worse and worse.
This morning I put a post over in the Merc/Mariner forum and ended up answering the question myself. Seems when you write something down and then read it, a light goes on.
I tore the engine down to the bare powerhead and pulled the injectors on 3 & 4. Both were plugged. I found another 1/8 inlet inline filter comming off the accelerator pump and it was full of gunk. I pulled all the fuel lines and let some oil out of the oil tank and ran it between my fingers and it seemed O.K. There was no doubt that there was dirt in the fuel system and a lot more than normal. I took apart the accelerator pump and it had dirt in it so I got to thinking and a light went on. More like the dummy light than anything brilliant mind you.
I realized that I had taken out the inline fuel filter because I had the Racor in it now but what I forgot was that the oil would now be unfiltered and that's where the problem was. There was a bunch of dirt in the oil tank and all my hard work rebuilding carbs was down the tubes.
So, those of you who are reading this and have engines with oil injection tanks, don't take out that inline filter just after the fuel pump just because you put in a fancy canister fuel filter. That little inline filter is still needed to filter dirt from the oil tank.
So anyway, my evenings next week will be spent cleaning and purging all the oil out of the system, rebuilding the carbs, fuel pump, accelerator pump and anything else in the fuel systems.
I'll post an update to this when I have her running again next weekend.
