j_k_bisson
- Oct 6, 2010
- 1,082
Re: 1991 Bayliner Trophy 2002 Transom Repair
The top I would guess is around a 700-1000lbs. I used an automotive engine lift to lift it up. But would not recommend doing it this way. It was very unstable. I have seen on here where some guys make a lifting stand out of 2x4 and stuff for this. That would be the more appropriate way of doing things. Deffinately have 4-5 buddies help you. I almost lost my top when it decided to flip over on the lift. We where able to save it from falling.
Good luck on your resto and post your progress for everyone to follow. It will become a bit of an addiction after awhile.
Jeff, fantastic! I'm in the beginning stages of redoing the stringers in my 1990 Campion Fishing machine (same hull and layout as the trophy). I'm popping the top and that seems fairly straitforward....what would you estimate the cap weighs? Your aluminum fuel tank looked in great condition...any pitting corrosion on the bottom? Your boat is damn near identical to mine other than the name "Trophy" on the side. thanks for the play by play on the resto......
