Check around the perimeter of the race make sure there is not a retaining ring which I believe there is none. The thing that makes it hard to remove is because the bearing overheated as indicated by the blackened balls thus "almost" welding the race. It will take a lot of force to push it out either with an hydraulic press or a 5 pound sledge hammer and a flat faced chisel. Just make sure put it against something solid like an anvil or a vise.
