Leaky bowl gasket was causing the issue, I cleaned again and put in a gasket from my extra carb. I also added another fuel filter to try to help with sediment from bottom of tank. Everything seems to run great. The electric choke does not work but I will mess with that some other time. How can i tell if the electric choke is working, is there a test? It is somewhere in the wiring but I have not gave it much thought due to the other problems.
